do they sell thoes for h22 and is it worth it to get one
launch control
Originally posted by phayze View Postdo they sell thoes for h22 and is it worth it to get one
And it really depends on what you're using it for. I would say it's worth it if you go to the track a lot. Besides that I dont really see why you would need a launch control
Originally posted by phayze View Posti just like it ccause of how you can read line with really redling tha engine
Do you mean redline? If it is redline, it's not a great idea. Why would you want to redline your motor? Unless you are racing on a track I wouldn't recommend it, but it's your car so you can do whatever you like, that's just my opinionLast edited by mozzandherb; 08-04-2009, 12:58 PM.
It only works when the car is stationary. Save your money and learn to do it the way we did before computer assisted launch control. Learn to drive your car. I can hold my car at any RPM I want with my right foot when I'm on the line. That couple of hundred dollars could get you something more useful, and learning to drive better at the track will benefit you off track as well.
Originally posted by visualpoet View PostIt only works when the car is stationary. Save your money and learn to do it the way we did before computer assisted launch control. Learn to drive your car. I can hold my car at any RPM I want with my right foot when I'm on the line. That couple of hundred dollars could get you something more useful, and learning to drive better at the track will benefit you off track as well.i agree and plus you get to know youre car better and you can actually learn from it like a what rpm can you launch youre car where you will get traction next to launching youre car with no traction and not getting good times at the track
Originally posted by MDJ-7BC View PostIsnt this also known as a 2 step, or is that something different?
There are two different types of launch control (2 step, full throttle launch, etc... whatever you want to call it). Spark, and fuel.
If you do it through the ECU, it's usually for fuel. It cuts off fuel at a specified RPM, and your engine will bounce at that RMP until you launch. I have mine set at 3500 with my Crome tune by MRX.
This is actually VERY bad for your motor, and you should never sit there and rev. It basically causes a very lean condition, which can lead to severe engine damage. If you want to use this at the track... do it just before you launch. Don't stage early and be a punk bitch revving your engine the whole time your opponent is burning out and staging.
I don't know if there are any software-based spark cutoffs. I'm sure the higher-end standalone systems that come with their own coil packs and such have it, but I'm quite sure none of the lower-end stuff (the cheaper Hondata systems, chipped stock ECUs, etc...) have it.
A fuel cut is more of a risk with forced induction. Additionally, if you have a fuel cut to save you from over-revving (as I do...) you can VERY easily lose your motor to nitrous. Hit that cut when spraying, and goodbye motor.
If you want a spark cutoff, MSD offers a good one. This is what people call the 2 step. It may even be the official MSD name, I'm not sure. I plan on getting one of these myself. They aren't incredibly expensive. Cutting spark is MUCH safer than cutting fuel. However, you do run the risk of hydrolocking your engine if you sit there revving. If the fuel can't be burned, or at least dumped out through the exhaust valves, it will act just like water... it won't compress, and your pistons might as well be smacking into a brick wall. Only, to add to the fun... once the red-hot internals shatter and that fuel vaporizes, you could be looking at a nice explosion, or at least a fire... Unlikely, in all cases but those of extreme stupidity... but it can happen.
I know a guy here in my town that has a 2 step on his civic. He goes to the track every now and then, he mostly street races though. He seems to have pretty good launches but he does run low tire pressure and he uses bfg g force t/a's. Ive seen him get better launches than some awd subarus and talons/eclipses.
