hy guys i am new to the cb7 I am friends with ray with the white cb7 I am having a problem with mine once and a while the engine bogs hard and doesnt go anywhere can anyone tell me wut it is??
cb7 sputter once and a while
Originally posted by CB7D@N View Posthy guys i am new to the cb7 I am friends with ray with the white cb7 I am having a problem with mine once and a while the engine bogs hard and doesnt go anywhere can anyone tell me wut it is??
Originally posted by CB7D@N View Postall that stuff is all new i even tried punching out the cat
Originally posted by CB7D@N View Postthe cat was on there from the factory never replaced and usually it likes to clog up and constrict air flow which i thought was throing off the oxygen sensor
A hollow cat produces a significant amount of backpressure, resulting in reversion. The burned exhaust actually gets forced back into the combustion chambers, resulting in a weak charge. Replace the cat. Hollowing out a cat is a really stupid thing to do.
It'll also do a number on your oxygen sensor.
That check engine light (CEL) is telling you that something is wrong. It is a VERY good chance that the problem that the light is reporting is the problem you're looking to fix (and if it's not... it's a problem you SHOULD be looking to fix).
Go here http://www.cb7tuner.com/vbb/showthre...t=Diagnose+CEL
Follow the guide, and come back here with your error codes.
