wats that?
    wats that?
    just got my car n alignment. after that when i make a hard or fast turn i get i bump sound. sound like is come from under the car. i dont know help
    What do you mean by "bump" sound? Can you elaborate further?
    Can you feel it, either throughout the vehicle or through the steering wheel?
    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
      have you checked your bushings and strut bar??
        Originally posted by JDMcb792 View Post
        Its your bushings those must be replace.
        try and be more specific instead of just tryin to get to 30 posts. theres more than one set of bushings on our cars in case you hadn't noticed.
        The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
          Alignment shops aren't supossed to do any sort of alignment work on a suspension with worn or broken parts. My suggestion is to take it back to the shop that did the alignment. Tell them that something is loose and ask them if they can take a look at it. If they say something is broken or worn out. Ask them why it wasn't noticed before your alignment was done.
          MR Thread
          GhostAccord 2.4L Blog
          by Chappy, on Flickr
            Is your car lowered with camber correction? A lowered car with 0 camber often knocks the upper conrtrol arms against the inside of the wheel well.
              yea the car is lower
