I have a 92 EX that is too far gone bodywise and I am swaping the benefits over to a good 92 LX. I dont want to swap ABS if I dont have to. Info plz
Rear disc swap. ABS needed?
http://WWW.DUBWISE.NET
My Job!
9DUBWISE 92 LXhttp://www.cb7tuner.com/vbb/showthread.php?t=142580
RHD ITR conversionhttp://www.cb7tuner.com/vbb/showthread.php?t=172577Tags: None
You do not need the ABS to run the rear disc brake setup.
I simply took off the ABS sensors, and swapped the rear cross-member and disc brakes.1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
Thank you so much. Still trying to get used to this site. Hard to move around and know what I am doing. Sorry for posting without reading everything first. Thanx 4 your time JM.http://WWW.DUBWISE.NET
My Job!
What about the car I am swapping from? Does it have the prop valve? Or do i have to get one off of a Teg? If so what year Teg?Last edited by 9DUBWISE; 08-02-2009, 12:54 PM.http://WWW.DUBWISE.NET
My Job!
Originally posted by James Matteu View PostYou do not need the ABS to run the rear disc brake setup.
I simply took off the ABS sensors, and swapped the rear cross-member and disc brakes.Originally posted by deevergote View PostYou'll need a 40/40 prop valve from an Integra to have the rear discs work correctly.Originally posted by deevergote View PostThe prop valve comes from the DA model tegs without ABS. The CB does not have this valve normally, since all rear disc equipped models also have ABS.
Interesting about the 40/40 prop valve, i thought i was a straight bolt on swap. i guess we learn something new every day!!!!. lets say 6 hours project with some help???...
If you just bolt on the parts, without swapping over the ABS (and I know nobody that has done that... some of the most hardcore guys on here won't even attempt it...) your rear brakes would grab as hard as the front, greatly increasing the risk of a spinout. It'd be like yanking your e-brake every time you pressed the brake pedal.
Originally posted by deevergote View PostIf you just bolt on the parts, without swapping over the ABS (and I know nobody that has done that... some of the most hardcore guys on here won't even attempt it...) your rear brakes would grab as hard as the front, greatly increasing the risk of a spinout. It'd be like yanking your e-brake every time you pressed the brake pedal.
Another quick note about the 4040 prop valve, it does not line up with the mounting holes for the stock 3030 prop valve and has a different bracket.
4040 on the left, stock on the right.
You can either swap brackets so the DA prop valve will mount in the stock location, or you can get creative and mount it some other way.
If you decide to swap the brackets, you will need a A T30H tamper proof torx bit to remove the bracket.
Picture of the T30H tamper proof screw used on both prop valves.
Good luck!
Originally posted by deevergote View PostOh yeah, I forgot about the bracket! Good job with the pics, frootloops! It's posts like that that really make this place a valuable archive!
The car i am using does not have ABS (92 LX). So does it have the prop valve already? Car is at work so I cant just look. Yes, awesome pics.Last edited by 9DUBWISE; 08-03-2009, 10:18 PM.http://WWW.DUBWISE.NET
My Job!
