help!!
well its kinda like a breather for the engine called the "PCV VALVE", that comes from the intake manifold, if i were you i would go to autozone or somthing simular to replace it or else or idle (rpm) will go up and down (repalce it)....if i were you i would not even touch it at all dude just leave it alone until you buy that new hose or else it could be worse for the idle and manifold...laterz!
Eso es como un respirador para el motor que viene del manifold de aigre que se llama "PCV VALVE", si lo quitas tu rpm va a suvir y vajar rapidamente, es mejor si vas a autozone o qualqier tienda que venda partes para caro, y diles que ocupas un mangerita para el motor y fuel injection systema, es mejor que lo dejes enpas asta que le compres la nueva mangera, luego se dana el fuel injection system, si tienas mas dudas o preguntas Mandame un mensaje the PM (private Message) adios!Last edited by pedroalcala; 08-01-2009, 12:34 PM.
______________________________
"I ran open header once, it was sooooo loud little kids were running for cover as I was cruising at 2000rpms. That was enough to know I shouldn't floor it."
Originally posted by seguvira View PostFUCK !!!!!! jajajaj
I hope they sell that PCV VALVE here in argentina.
I will never touch another thing !!!
THANKS
si creo que lo vendan en una tienda, deve de aver un lugar, todo lo que ocupas es la mangerita, y las abrazaderas, si es que no se quevraron.
Originally posted by deevergote View PostI don't even know if mine is hooked up... Then again, there are a lot of things that aren't quite right with my car... so I can't use that as a reference! My car is in desperate need of attention.
