help!!
    help!!
    Well this morning i was cleaning the engine and i broke this plastic thing=
    Photo before i broke it=
    I managed it to fix it the best as posible...
    żżżIts like a valve or something important???
    Hope you help me.
    Sory my english im from argentina ! haha
    Its your pcv valve. They're cheap, less than 3 dollars at a parts store
      well its kinda like a breather for the engine called the "PCV VALVE", that comes from the intake manifold, if i were you i would go to autozone or somthing simular to replace it or else or idle (rpm) will go up and down (repalce it)....if i were you i would not even touch it at all dude just leave it alone until you buy that new hose or else it could be worse for the idle and manifold...laterz!
      Eso es como un respirador para el motor que viene del manifold de aigre que se llama "PCV VALVE", si lo quitas tu rpm va a suvir y vajar rapidamente, es mejor si vas a autozone o qualqier tienda que venda partes para caro, y diles que ocupas un mangerita para el motor y fuel injection systema, es mejor que lo dejes enpas asta que le compres la nueva mangera, luego se dana el fuel injection system, si tienas mas dudas o preguntas Mandame un mensaje the PM (private Message) adios!
        FUCK !!!!!! jajajaj
        I hope they sell that PCV VALVE here in argentina.
        I will never touch another thing !!!
        THANKS
          i believe u could also get it at ur nearest chop shop there in argentina..anyway,good luck..
            Originally posted by seguvira View Post
            FUCK !!!!!! jajajaj
            THANKS
            yea they might sell it, all you need is the hose and if your clipers are ok then use the same ones if not then buy new ones
            si creo que lo vendan en una tienda, deve de aver un lugar, todo lo que ocupas es la mangerita, y las abrazaderas, si es que no se quevraron.
              It's a standard part on newer cars. I'm SURE shops there sell it.
                ok thanks !
                I prefer not to use the accord this weekend until I buy the valve.
                I´ll steal my moms civic ! muajaj
                but nothing compares with the CB!!
                CHAUUU
                  i broek mine yesterday, im driving my car.
                  i just pushed a screw into the line so it would still create a vacum
                    I don't even know if mine is hooked up... Then again, there are a lot of things that aren't quite right with my car... so I can't use that as a reference! My car is in desperate need of attention.
                      be lucky that i am not in nj, there would be meets every weekend to get shit fixxed
                        I wish you were in NJ so that would happen!
                          yea i got work to do
                          wish i knew someone who would fix my rust for free
                            Quesiton:
                            PCV goes to the Intake Manifold, if I'm not mistaken, but I've seen many people use a little filter in its place? PCV's aren't a necessity? Or they are only a necessity on Automatic cars?
                            Thanks in advance!
                              partners ! jajaaj
