In order to lower my stock 91 CB7 Sedan What will I need?
    I know already that ill need some springs and struts/shocks but is there anything else ill need to do the drop? ie spindles, cambers? I know nothing about suspension work...
    Originally posted by Makaveli2k
    White girls make the world go round. If I were to be stranded on an island and I could only 3 things to bring with me It'd be 2 different white girls. And a Smashing pumpkins Cd... I hear they like that shit. =p
    http://www.cb7tuner.com/vbb/showthread.php?t=1003
    http://www.cb7tuner.com/vbb/showthread.php?t=36278
      Get those two things, put them on.
      Then get an alignment.
        You will need:
        Springs - get quality. They aren't that expensive
        Shocks - KYB GR2s at the very least (and these are only stock replacements). Koni Yellows would be ideal, and they have a lifetime warranty, no matter how low you go.
        Camber kit - not "cambers". Again, get quality. A $50 kit from ebay can break (I had it happen to me), and you WILL lose control of your vehicle if that happens. I HIGHLY recommend TASauto.com's adjustable upper control arms. I have them on my car, and I couldn't be happier. The front is more important than the rear, though you SHOULD get both.
        Alignment - Any time you touch your suspension, you need an alignment. Firestone will give a lifetime alignment for about $200. Pay once, go back as often as you want.
        In addition to those things, check the condition of your bushings, ball joints (this is very important! if they fail, you crash), wheel bearings, brake components... Anything that needs replacing, replace it. Suspension is one of the easiest things to work on with our cars, but it is also one of the most dangerous. Make sure it's right, or you're putting yourself at risk. Don't go cheap, don't halfass anything, and don't do something until you know what you're doing.
          It's a good deal, but also some fine print. Certainly doesn't transfer between cars, and maybe not between Firestone locations.
            It SHOULD transfer between locations... but no, certainly not between cars.
