Suspension Problem (werid noise)
    Most likely it's the shock. Replace it before you crash. That is VERY dangerous.
      Exactly. Fix it as soon as possible. Don't drive the car until you do if you can help it. It'll be a lot more work, and MUCH more expensive if you hit something!
        i have the same problem except its more of a slight knocking opposed to ticking. i'm pretty sure it's my CVC joints tho.
          If it's when you're turning, it's your axle.
            yeah i've got a bad UCA mount on the D/S in front. One of the anchor bolts kinda ate through the mounting location. I've got NO idea how to fix it though. Right now I'm using really tough fender washers to make the nut ontop distribute the load a little better but it still scares me. It looks like i'd need to replace the entire engine bay or something...Its all welded together.
              A new plate can probably be welded in there.
