car over heating, need help asap!!!!
    hey wats up guys i own a cb7 but i need help with my bro car he got a 91 civic hatch with a b18 swap but he car gets ova heated and its not the relay or termostate nether i waz thinkin if it waz the coolent sending unit ? agin im srry 2 post this he but i really need sum help here thanks
    may have a bad fan switch...you can jump the fan switch, and see if the fans turn on...
    you can also power and ground the fans to see if they actually work as well...
    just a starting point...
      nah but the fans turn on idk its weird
        no leaks?
        maybe a bad w/p? or headgasket?
          its not w/p or headgasket becase there all new
            maybe you got air in the system?
              If you have not replaced the old water pump, its the water pump. I guarantee it. Check your coolant hoses...one should be hot and the other cold.
              Otherwise, you can check your thermostat; ideally use a Honda OEM thermostat.
              DEVOTE
              FS: Lokuputha's Stuff
                he says, the motor has a new water pump, headgasket, and also said its not the thermostat....dont people read?
                  did you bleed the system? Maybe the waterpump isn't pumping?
                  AD5OS
                  FOLDING@home
