Oil Leak From mysterious Place?
    Today I discovered another leak today after replacing all the gasket seals.
    After driving, there was a lot of smoke coming up from the throttle body area, right underneath it look. Which now i know its not my gasket seals.
    I need to find this other place now.
    any help would be great from what i saw when just looking under the car i saw oil drops from these locations.
    This place has oil on it this is a thing coming from the firewall area.
    This is one of the Four Pipes infront of the throttle body that has oil on it.
    Oil Dripping from this Pan with four pipes under the car.
    oil dripping from this one area on the body under the car. some corner of something.
    another picture of that pan
    and the throttle body itself, where the smoke was coming up from.
    so any help would be great. im planning on taking it up to a mechanic for them just to inspect the under body but still any input is great.
    Looking For Some CB7Tuner sticker, No Credit Card to buy one. Anyone wanna give me for free?
    the oil pressure sender likes to leak alot and drip onto the exhaust causing a little bit of smoke on occasion.
    The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
      Hmm well i dont think its that. cause after opening my hood it was smoking alot and right after opening look under car and saw multiple oil spots leaking
        i'd check it out at least. mine was leaking and the whole back of my block was covered in oil. incase you dont kno, the pressure sender in on the back of the block, above the oil filter, right below the middle of the intake manifold. going by your pictures, if your valve cover gasket is leaking, (which i believe you said you replaced?), then my money is on that oil pressure sender. if thats it, its like $10 at honda.
          have you thought about it possibly being a power steering line leaking? looks like a good possibility to me. and as stated above oil pressure switch is a good source for leaks in that area also.
          Dave Estes (owner of) DB Customs & Automotive Repair
          http://www.automotivecustomworld.com
          Just check it out!!
          free people search http://www.dbcustoms.ws
            Get a can of Gunk Engine degreaser, SOAK the engine compartment and let it set, spray it clean, then start the engine and look for your leaks. Your bay is FILTHY, and oil likes to travel around. A clean bay will make it much easier to find the leaks. It would also help if you bought a Haynes manual and learned what those parts are that you're trying to describe. The more you learn about your ride, the easier it will be to both fix and ask for advice.
              thats what I was going to advice clean the whole thing and then keep a close eye on it and you will see where the leaks coming from because eventually oil will travel down and hit other things.
              93 ex sedan
              automatic
