Legend Calipers on a cb7 upgrade
    Has anyone considered a conversion on the front brakes using Acura Legend front calipers on a cb7?
    Will it work?
    Will the bolts match?
    I know that these is a thread somewhere but I can't find it!
    Thanks!
    will work
    the nipple will be pointing downward though, so air will stay in the caliper
      I was planning on doin that, but yea they do fit.
      ANd 1st Gen Acura Vigor Brakes as well they have 11.1 in rotors I believe
      What's needed is
      Vigor rotors, calipers, and caliper brackets.
      We can even use our stock brakes lines.
      Originally posted by slick View Post
      but remember in order to properly bleed the front brakes on the dual pistons you have to take them off and bleed them upside down side the come off a car with trailing calipers and our accords are leading
      there is a full sticky about it in the suspension/ brake section
      My ride History:
      Accord 90 lx auto: Gone
      Accord 91 dx MT: Gone
      Accord 92 lx auto: Gone
      1st to D.I.Y custom RED/CLEAR's
        does the whole caliper sit higher than the brake line if the bleed nipple orientation is an issue?
        If not, then the brake fluid could be filled backward from the caliper bleed nipple into the M/C reservoir then there would be no airlock issue.
          http://www.cb7tuner.com/vbb/showthre...egend+calipers
          My ride History:
            Will it work?
            Thanks!
            Accord_SIR on this forum has done the conversion. You may want to contact him.
            http://www.cb7tuner.com/vbb/showthread.php?t=5384
            600HP" 1990 ACCORD LX COUPE COMING SOON
            CLICK HERE TO VIEW MY 1990 CB7
              i did legend brake upgrade a few months ago...works great!
                Ok a lot of usefull information here people.
                Thanks!
                The only reason why I was thinking of upgrading is because, according to me the brake systems on on the LX models with rear drums are completely useless.
                When i first got the car i replaced every single part on that brake system and the brakes are still not up to what i expeceted them to be.
                After some reserach here I found that the reason for that is the rear drums get looses after some normal driving, yes the brakes were great for the first couple of weeks, now the brake pedal travels down about half way untill the brakes really grab, so this is the only reason why i was thingking of upgrading.
                Thanks for all the info!
                  Thanks!
                  the stock accord brakes were designed fine from honda...not useless...they do work; they stop the car...the cb7 accord is suppose to be an economical car and was never meant to be a race/sport car, therefore didnt need perfomance brakes. but when you drive fast and mod your car, you gotta stop fast...therefore you'd wanna mod/upgrade your brakes. btw, drums require adjustment from time to time
                    Well I am not driving fast, nor I am driving crazy, bottom line is why all the other Economical that I have driven have good brakes and my accord doesn't.
                    I have already met with some people from Ohio Accords forum and seems that if you have the LX model with the drums, you are out of luck, if you have the EX or SE with the rear disks you don't have that problem.
                    So what do I do upgrade the drums to disks or upgrade the cb7 front calipers to legend calipers.
                      you can do both upgrades like i did, front 2 piston, and rear disc conversion...i did rear disc 1st. cause it was cheaper.., pulled off parts from a junkyard cb7 ex and worked fine...and i figured i upgrade the rear 1st to compansate and then upgrade fronts after cause i didnt want badass front brakes and still roll on drums in the rear...but its up to you
