Leaking mastercylinder???help!!
    I don't see what's tha promblem but everytime I put brake fluid n I run my car it's seems that it's leaks some where cus I checked under tha hood an I notice brake fluid spilled over some engine parts but not too critical, should I need a new master cylinder or is there a salution to fix a leak...
    Is it only spilled around the master cylinder? Wipe it clean and check the next day.
      Make sure you arent overfilling it.
        make sure the metal wire piece that's holding the reservoir to the MC is secure.
        Yes my name is Dang, Don't use in vain
        1992 Honda Accord EX (Coupe/Bordeaux/Auto)
        1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
        2008 Honda Accord EXL (Coupe/SanMarino/6spd)
          Clean everything very well and look for the source of the leak.
          Brake fluid is VERY corrosive. It will destroy anything rubber, and it will eat away your paint. If you haven't cleaned it up carefully, do it NOW. If it eats away at your mounts, belts, and hoses, you'll have problems. If it eats away at your wire sheathing, you'll have more problems. If it eats away at your paint, your engine bay will rust out.
            Thanks
            Yea I think I should do that cus I think it's coming from
            one of tha little brake lines cus I felt tha line wet with brake fluid, but even if I tightin it what if it still leaks??
            man this is causing waste of fluid n not making my brakes not to work well
              If tightening the line doesn't fix it, you may have to replace the line. Clean everything first to see if that IS where the leak is coming from before you go messing with anything. There's usually no reason why a line should start leaking, unless the master cylinder was recently replaced and things were installed incorrectly, or something pulled hard on that line (did you recently swap the motor?)
              A leak in the brake hydraulic system can be very dangerous. If you get air in the lines, your brakes won't work until you bleed them. FIX THIS PROBLEM NOW! I honestly would not drive the car until you've fixed it.
                  No I haven't done any swaps, but I took it to to a shop for a check promblems before it started doing that , it cost alot for mastercylinder n labor n other shit, damn basters try to rip me of, so I took it home brake bleed my self n it wus working good until it started doing that again only leaking fluid, I just wounder if those guys at that shop didn't do anything to my car to get more money out of my pocket or I did something wrong... But I'll check n see hopely it works good, yea I won't drive it, but damn I love my cb7!!!!
