i have a 91 accord lx f22a1..my question is would a f22a4 dizzy plug and play with the a1 motor?
distributor question
The 90-91 F22A1 and F22A4 are identical in every way other than the F22A4's exhaust manifold. The distributors should also be the same thing.
Go to www.hondaautomotiveparts.com and compare part numbers. If they are the same number, they are the same part.
id get the distribitor o ring and a new cap and rotor call it a day.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Yes, that looks to be an external coil dizzy. It's not an F22A4 piece in that case.
To use it, you'd need an external coil and the wire that goes to it. I don't know if there are any wiring differences as far as the harness goes. I don't believe there are, but I won't say anything definite.
Someone here WILL know that.
ive swaped a 93 and 90. there is a weird main harness plug on the passenger side thats kinda like a red brownish color. i think that has something to do with the internal coil. on the 93 there are three of almost the same grey color plugs on the same side of the harness. not sure if thats any help but it confused me on my 90 swap.
if swappin a a4 motor into any 90 or 91 the harness should already be good to go and ur stock dizzy will still function properly.
its very simple. unplug the orginal one, (should be three plugs) loosen the 3 bolts that hold it to the head (12mm) and instalation is backwards of uninstall. the dizzy only goes in one way, from what everyone says BUT i did have a 93 that would go in either way. if u put it in and it turns over and won't fire take it back out, spin the dizzy 180 degress and boom good to go.
you don't have a external coil on ur 91. it didn't come from the factory that way. ur coil is already inside ur dizzy and its all plug and play
ur dizzy only has 4 spark plug wire plugs not 5. if it does have 5 u have the wrong dizzy.Last edited by chillin943; 07-28-2009, 06:47 PM.
