Yo I got a guy wanting to sell his CB but it got an engine knock. I've heard of engine knock but haven't dealt with one before. My question is what the hell causes that? And how much work do I have to put in to handle that? He selling the car for $500 so I'm still debating if its worth it depending on what you guys say about the knock.
Engine knock, knock, knocking
Possibility is rod knock & piston slap when the piston is moving freely when it has little compression in the cylinder bores.Last edited by PIMPCORD; 07-26-2009, 08:11 PM.Feeding trolls is my profession and hobby.
I have the ability to speak and write the idiot language.
Masters Degree on Trolling & Counter-Trolling
assuming it is a rod knocking, heres what youd have to look for and fix, first of you need to determine whether the cylinder walls are ok to be honed or whether thed have to be bored to be fixed, if honing will do, all you need is new piston rings, rod bearings and main bearings, and full gasket set. i'm in this situation right now, or if you needed to bore it add pistons to that list and machine shop time! but for the price its worth it if the body and interior are decentRandom Customs
Praise the lowered
Originally posted by nostringz View Posthigher octane fuel should help too. clean carbon deposits up. Shell V-power for a tank or two...
Rod knock is a regular and usually fairly loud 'knocking' noise that rises and falls with rpm and may be constantly apparent but may also only be apparent when the engine is under load (even a light load such as revving in neutral). Combustion 'knock' is usually quieter, 'rattlier' and usually only apparent when the engine is under heavyish load.
Rod knock is terminal, combustion knock can be be fixed if you can locate the cause.Regards from Oz,
John.
Originally posted by CB7Man View PostSo my knock sensor is bad and at 3K if I give it a good amount of gas, it makes this rattle noise, let off the gas it goes away. It only happens between 2.8-3.4K
Also my engine runs way better before the CEL comes on...
I'm pretty sure my CB7 (Australian delivery) doesn't have a knock sensor, I'd be surprised if any of them do(?). Without hearing it it's hard to diagnise just what sort of 'knock' your engine has, but 'pinging' and rod knock each make fairly distinctive noises. I think you need to have an experienced person have a listen, and check out what CEL you have.
A combustion 'knock' (ping, rattle) can be caused by a number of things:
Fuel too low octane causing pre-mature 'auto-ignition' from the heat caused by compression (unlikely with low compression US market F22a engines)
Over advanced ignition timing
Engine running very hot (ccoling system problem)
'Hot spots' in the chamber, i.e. unwanted sources of auto-ignition caused by e.g. carbon deposits glowing red hot, spark plug electrodes glowing red hot (plug is wrong heat range, i.e. too 'hot' a plug), exhuast valve glowing red hot. Hot spots could be caused or worsened by a lean condition (lean mixtures burn much hotter than rich or 'adiabatically' correct mixtures).Regards from Oz,
John.
