bummed? help!
    bummed? help!
    k, it's a f22a1 motor in a prelude, anywaies, i tested for fuel, and the fuel pump is out, so i went ahead on change the fuel pump..put gas, and car still cranks, but it won't start. checked for fuel again, there's fuel reacing the fuel rail. tested for sparks, and im reciving sparks. main relay, ignition realy is good. befor the car stoped running, it would bog at low rpm then it'll stop. but if i give it gas, like im going to race, the car wouldn't pull at all..can anyone help me here..
    Ecu bad, O2 Sensor, where are u getting fire????, Take off the valve cover and See if the cam is broke, happen to me once
      Whats actually wrong with your car?
      You havn't described any problems that seem to relate to your current issue.
      Does it start?
      Does it start then stop?
      Or is it just not running right?
      My 5.7 LS1 Holden Ute
        Does it start?
        x2 what code is it throwing?
          Code is throwing, speed sensor and electronic air idle control valve.
            -Car won't start anymore, when it use to start, the car will bog at low rpm and it'll go away, or when i slam the gas, it'll bog all the way thru.
            car doesn't start, got sparks from the ignition system, and new fuel pump.
            Does it start?
            -it use to, but now it doesn't
            -it only did it once, right after that, the car never started.
            no, it never ran right, like what i said, bogs on low rpm then it'll stop, half throttle - full throttle, it'll bog thru the whole rpm.
            all i know is that my ignition system works fine, and i have a new fuel pump
              How is the catalytic converter ? My 88 Prelude recently had a clogged cat and it acted like that.
                haven't checked it...but im going to do that, just incase it's not the one, any other ideaz
                  Fix the errors shown by your CEL, and see if that fixes anything. Tackle the identified problems first.
                    you dont need to replace your IAC just take it off and spray it out with parts cleaner... they get filled with carbon dust and they are like 130 buks new... so save you some money
                      x2 hell if thats what you car is saying wrong with it diagnose those problems, if you baby says daddy im hungry you wudnt go changing the diaper would you
                        Is it firing in the right order? I.e have you accidently switched the dizzy leads around?
                        Have you done a compression test?
                        Spark + fuel + compression + correct timing = A running engine
                          k, im going to fix those problems that i've diagnose with the check engine light, but yes im getting sparks, fuel, and i do have a good compression, and my timing is correct, i corrected the timing when i first got the car cause it was hella off....
                            anyone? fix the speed sensor and the idle air control valve.. still not working. main relay is also good...
                              checked for fuel supply again, remeber, the fuel pump is new, im not getting fuel into my fuel filter or fuel rail?
