Help! Replaced headgasket and head and it bent valves?!
    I have no idea what you're asking... make sense, and I'll answer your question.
      ok
      me and my dad started the engine. it hade a slight knocking sound from the engine.my dad waz reving the engine a lil and then the timing belt snapped. any one heard of a f22a1 doin this?
      i found a h23a1 with tranny for 450. which is better h22a1,h23a1, or f22a1
        Was the timing belt new?
        What did you do in your "rebuild"?
        My 5.7 LS1 Holden Ute
          Ugh my head hurts from reading all of this. First off, TDC IS KEY. Three words to live by!!!!
          When setting the engine to TDC on the compression stroke for cylinder #1, YOU MUST REALIZE that the crankshaft rotates twice for every single rotation of the camshaft. So, if you simply set the crankshaft to TDC without looking at the position of the camshaft, you may actually be at TDC on the exhaust stroke for cylinder #1!!!
          After you get the crankshaft (by flywheel indication or by checking actual piston location), check the camshaft sprocket to make sure the camshaft alignment mark is at the TDC position as well.
          Rastalude: Not attempting to come across as an asshat here, but I'm confused as to what you're asking. Are you asking if a timing belt failure is common on an F22Ax? it is if it hasn't been properly replaced at the specific interval of around 100k (good rule of thumb). As for the "knocking" sound, it could've been a few things. If your timing is off, your crank will surely be off as a result, due to the cam being off. Slightly bent valve? did you notice any obvious differences in intervals of compression *meaning, did it "chug"? Spun bearing? likely results in the rod making the knock sound. Please be a little more specific!
          life is good.
            it waz just knocking
            it waz just a knocking sound like bottom end and we did seals water pump head oill pan gaskets and valve etc
              so you replaced the valves? or just checked valve lash?
                update
                we took the valve cover off it had broke the cam at the end where the cam goes and the cam broke off but the oilpump waznt sending oil up and locked head up
                  hey ok have another ? my friend has a intergra and the computer is actin up and we cant find a intergra to get the ecu. Been on this site and readin up on ecu i learned a lil i think but can u use a civic ecu if the motors are the same. because he has a b18b1 and if im not misstaken the some civics come with the same engine.
                    Ok, if you hijack one more thread, and whore one more post, you're banned from this site. We don't need more inconsiderate morons around here... we've got enough already. This is the second thread that you have asked that totally unrelated question in (unrelated to this entire site, even!)
                      hey sorry
                      i just thought if i post on different post that i would get a faster response because i be in kind of a hurry trin to drive man but sorry
                        I'm in a hurry to piss, so I'll do it in your fridge. It's more convenient.
                        Show some respect, or leave. This is your last warning.
