Leaking coolant all around the tranny
    my 90 accord ex 5speed is leaking coolant around the tranny. i see it on the top of the tranny and the bottom. im getting a grinding feeling and sound coming out of 1st gear. not sure if the grinding is related to the coolant but i noticed these at the same time. this aint good. starting to hear skeaking and all types of stuff now. car has 210k on it. please help yall
    i feel the grinding at the pedals btw
      your trans doesn't have coolant in it so it is probobly the hose going into the head below the distributor or the water pipe that goes into ur thermostat housing or any of the other hoses that flow coolant
      ''COUPE''
      ''WAGON''
        i figured that but all the hoses were dry. what bout the grinding? im going to look at it again
          well i have felt the grinding in my clutch pedal before in my 92 accord lx...replaced the slave cylinder and it stopped
            ya so it was a hose. clamp wasnt on tight. grinding is my clutch goin
              try replacing the slave cylinder first its inexpensive...only about 20 bucks or so..just make sure you bleed it all the way...you could even try bleeding the one you have now to see if air bubbles may have gotten in there
                ya but how much would the labor cost to replace the slave cylinder? could i do it myself?
                  Was it the heater hose?
                  Tomi
                  My CB9/Wagon Thread Start to Finish:
                  http://www.cb7tuner.com/vbb/showthre...ighlight=wagon
                    well im not sure how much labor would cost but i done mine and it was pretty easy...you just have to get enough fluid for it....cuz u have to take off the old one and then when u put the new one on just make sure u have a friend to help you bleed it...its easy to find its at the front of the car....but its kinda non space efficent...but isnt too hard
