i know this isnt the place but i have a suspension Q
    i want to stiffin up the rear suspension and i was gonna start with a sway bar, but when i proped up the car i didnt see where one goes
    does anyone have a picture or knows where i can find one to show me what the hell im doin
    You can't post anywhere but the beginners area until you have 30 meaningful posts....so in your case, you did post in the correct area.
    A stock rear sway bar came on the EX and SE models only.
    If you get an aftermarket sway bar like the suspension techniques, then you need to get a rear crossmember from an EX accord, because it already has the proper mounting holes for the sway bar.
    I recommend the Progress rear sway bar though. Its the largest one for the CB, and it mounts differently. You have to drill special holes to mount it, so it doesn't matter which rear crossmember you have. Basically, if you were to buy the Progress bar, it has instructions on where to drill, so that's how you know.
      ok, i got an LX. What you're telling me is that if i get the Progress sway that all i need to do is drill holes to mount it?
        Yes. All the brackets and end links should be included.
          so with that, it should be pretty straight forward?
          its something i could do myself
            If you have the tools and some basic knowledge, yes.
              i dont know squat about suspension!
              should i take the risk in doin it myself
                read for yourself
                http://www.progressauto.com/ecom/download/62.1011.pdf
                  it doesnt sound like it should be too hard, but with my cb not having a stock rear sway do i still need the ex crossmember
                    For the progress bar, no. In fact, the progress bar is easier to install on your car because you don't have to remove the old sway bar because you don't even have one.
                      alright kool!
                      thanks for all your help buddy!!!
                        no problem. good luck
                          don't be afraid, realize that a car is just a bunch of stuff bolted together.
                          I could be mistaken, but I don't think you'll be modifying anthing that's critical for safety for the rear sway bar installation, and basically all you'll be doing is adding stiffness and rigidity to the rear of the car, not taking anything away. If the rear sway bar ends up failing for some reason in the future, the worst that will happen probably is that your car will handle again like it currently handles.
                          read up on it and decide.
