Rear Break Light On Dash?
    Ok So I started the car up today for a daily drive, to my buddy's garage.
    and saw this light on the dashing saying Rear Break?
    I really had no clue, I ask my buddy he had no clue still.
    So explanation would be great. im thinking its like a sensor for Break pad Wear?
    Picture of where the light is.
    Looking For Some CB7Tuner sticker, No Credit Card to buy one. Anyone wanna give me for free?
    It could be possible that one of your brake lights is burnt out. I had some funky wiring on my cb a while ago just on the tailight harness. It'd be intermittent and go on and off alot. I just replaced that lil harness part that the sockets are on and its been good since. Maybe your 3rd brake light burnt out also it will tell you. If you checked that sorry my bad. Do you have abs? Post a reply and I'll go from there.
    "Cause hooking vtec to a switch is stupid. Why not hook vtec up to a clapper and just slap your self in the face everytime you race."
      Hmm my Lights seems Fine,
      And yes i have ABS,
      Could it be my break pads?
        that has nothing to do with brake pad wear.
        you either have a burnt out taillight bulb, corroded bulb socket or bad sensor in the taillight (see pic below).
        later.
        Avoiding dirt at all costs
          like he said. Lol I just went out and took pictures but you beat me to it. Its your tail lights after reading my service manual we don't have anything like that, that reads things wrong with brakes or anything well besides your brake light coming on or abs but nothing for pad wear. I'd check your wiring you might have a short some were. Are you sure all your bulbs are good? If so pull out your harness and check for loose connections.
            i kinda had something like that happen to me...when i did my h22a and manual swap, i wanted to change the gauge assembly to a 5speed assembly to get rid of the auto trans gear position indicator on the dash. i picked up a ns 5speed complete assembly from the junk yard and put it in...everything worked..except that brake light indiacator came on..i could have swore my brake lights were all good prior, so i double checked my lights and they were fine...turns out, the 5speed gauge assembly i put in, had a burnt circuit board, causing it to think i had a bad brake light...i ended up taking apart both gauge assemblies and swapped the fuel/temp gauge meter over and used my original assembly and it was all good...
