help. Walbro fuel pump question
    I did my turbo this weekend on my f22. Put in the 255 walbro fuel pump. My question is.. We crimped the wires together. There is no worries right?? We didnt shrink it or anything so the wires are exposed. Usually fire needs oxygen so i am figuring it should be good.
    Thanks.
    Thanks.
    Well if the positive hits ground it will short or spark and that fuel pump will stop working (at least for a moment) , plus when debris and oil gets in the connection it will start to lose some of its conductive capacity, and then you've got the issue of the connection loosening from vibration.
    Although I'm not sure of automotive electrical connection standards (standards are different for different applications), Probably the best bet is to go get some automotive electrical twist on connectors and connect it that way, then tape around the connectors to further keep dirt out. In the meantime throw some electrical tape on or something. Actually, come to think of it for machine environments like cars there are screw on style clamps that secure the connections against vibration loosening. I'd just call up the auto parts store and ask them.
    But for a week or so it should work fine. I'd look to make the connection more secure against vibration and protect it more against weather though.
      please no screw on connectors. solder and heat shrink, thats the only way to go.
      The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
        if i take it off i am soldering it! no caps or screws shit..
          I use environmental splices. They look like butt splices, but when you hit them with a heat gun the outside rubber heat shrinks and then the center sleeve liquifies and solders the wires. Very sweet. Also very easy. Takes about 1 minute to do 2 wires if they are already stripped
          http://www.edmo.com/index.php?module...&prod_id=19475
            i took it off today and soldered it and heat shrunk it. So now its done right w/ no worried.
            Thanks guys!
