Does anybody know about Ebay's timing belt kit?
Timing belt kit
Ebay doesn't make anything. It is just an auction site for people to sell things. Therefore the quality of "ebay" kits can vary substantially.
Honestly, if your timing belt skips or snaps, your motor is very likely going to be totally destroyed. I wouldn't trust anything but Honda for a timing belt, or at least something of equvalent quality. The few extra dollars you'll spend on the quality parts will save you a LOT of money when your motor doesn't blow up!
Originally posted by sugar View PostDoes anybody know about Ebay's timing belt kit?
Whichever kit you get, make sure to do a close visual check of the timing belt tensioner pulley that they send as a replacement and see that it is identical to the one that is on your car, as failure of that unit is often the reason for timing belt failures.
I bought this kit and I haven't had any problems. The seller is great as well.
http://cgi.ebay.com/ebaymotors/Timin...Q5fAccessories
They are not oem Honda parts, but they are supposed to be parts that are made by the oem part manufacturer. They just don't say Honda on them.
The kit comes with everything you could ever need to do a timing belt change. Most people on here will tell you to use oem Honda parts or nothing at all. But I was in a budget crunch and really needed my timing belt changed. This kit worked great. The choice is yours.
Originally posted by deevergote. View PostThe window regulator I got from Rockauto was garbage... I won't be buying from them again.
The OEM Honda kit is $157. It's NOT that expensive. Do it right.
Does the honda kit include the pulley/tensioners?
sugar...you want to order NEW springs that go on the tensioners...the old ones will not suffice____
Save money by purchasing a timing belt package that uses all Genuine Honda parts. All parts in the kit are genuine Honda components. This package includes the timing belt, balance shaft belt, water pump, power steering belt and compressor belt. These are the most common parts replaced when servicing the timing belt. The timing belt should be replaced every 70,000 miles. Fits all 90-93 models.
Part #2814405
Price:$156.95
Doesn't look like any tensioner parts.
oooo...well...huh.
does include the water pump...but yeah no pulleys...and no seals either...course those are like $5? ooo...oil pan gasket...vc gasket...spark plug tubes...dizzy. i'm repeating my self my bad
I didn't replace anything but the belts at my 90k (actually 102k) t-belt change For the most part everything lasted until my 2nd (190k) t-belt change, however,
by 200k the water pump was leaking through the weep hole, the oil seals were leaking (cam and crank), and the pulleys were not good anymore...they weren't shot, and might could have gone another 30k with no issues...but you could REALLY tell a difference between the new ones which is why I'm not so sure they could have gone much longer.
When I did that I was 17 and didn't know shit...thought saving money was a good idea...I'm lucky it didn't bite me in the ass.Last edited by bcjammerx; 07-19-2009, 11:11 AM.____
The TAS Auto kit doesn't include the tensioners. When I added all the extra parts that the eBay kit includes, the TAS Auto kit runs around $320 for everything.
Versus the eBay kit for $173 w/ free shipping.
Is OEM really worth an extra $150? I gotta admit I'm a bit skeptical, there's so many of these auto parts that are rebadged - does anybody have any proof that they're worse, or is this just one of those "Peace of Mind" things?
And by the way, is there anything else that people would recommend replacing while doing a timing belt change? I'm set to do one at 200k, and want to change as many things as I can.
Found the answer to my question!! Sounds like, at least with the tensioner, there's definitely a reason to go OEM... yikes:
http://cb7tuner.com/vbb/showpost.php...1&postcount=10
