f22a1 cam vs f22a6
    f22a1 cam vs f22a6
    hi, i want to know what is the difference between the f22a1 camshaft and the f22a6 camshaft? when i go buy the f22a6 camshaft, how you sure is the f22a6 camshaft? thank
    the a6 has slightly larger lobes.
      The F22A6 camshaft will be from an F22A6. The cost will be about $20.
      And Keith... how is he going to measure the lobes?
        kk, i know a f22a6 camshaft came from a f22a6 engine, but when a buy a f22a6 cam, they have a part number on the cam or somthing to see if is a 'real' f22a6 camshaft. thank
          There probably is some sort of stamping on the cam. I'm sure someone has one handy to check. I haven't had an F22A in my posession in a very very long time...
          The most cost effective way to get a camshaft is to just go to a junkyard... there you can pull it yourself, and you'll KNOW what it comes from.
            kk, but every junkyard don't want to sale the cam only. i found the cam shaft from a guy near my house, but i just want to make sure is a 'real' f22a6.
              Really? Man, the junkyards around here have nothing but camless motors... I saw a guy walking around with 6 cams once, all F22A cams.
                I have the camshaft from my A6, it's marked "4B" on the dist. end, I am not sure if the A1/A4 cam would be marked the same or differently, maybe someone else can chime in.
                  ok, thank you, i have a f22a4 spare engine, i'm gonna check the end of the cam to see if is the same.
                    N/P, yeah, see what it says. There is really not much info about the specs on the A1/A4 cam and the A6 cam.
                      you know I remember looking at my a6 cam...when I swap 'em I'll try to remember to look for the numbers that are on 'em and post up
                      I keep saying I'm going to swap my a6 parts...but WHEN DAMMIT WHEN!!!
                      ____
                        pt3 vs pt6 ecu, what is the difference
                          i heard upgrading the camshaft helps the CB merge into the highways better... The stock F sucks!
                          Be Clean
                            Wow...a post where that johnl guy didn't repond with a 800 essay about the history of the cam.
                            Info is nice but there is a limit...lol
                            Deever's gonna be sad that he won't have anyone to argue with for 6 posts...lol
                            ( j/k deever & johnl....lol )
                              F22a1 has an R5 near the dizzy spline.
                              F22a6 has an R6.
                              I didn't notice much of a power difference with the PT6, I need to adjust ignition timing prolly. Balance belt delete was nice for the revs
                              RoaR MRT
