something is wrong with my CB7 there are times i am driving on the freeway and it doesn't want to accelerate fast it goes slow, it starts working good once the check engine light turns on and the sport light (Green "S" light) start flashing, after that the car accelerates how it suppose to... someone please help me! tell me what is wrong with my CB7!!!
something wrong with my CB7 HELP!
sounds like you have a transmission problem...on the passenger side underdash, look for the scs connector. its between the kick panel and glove box...kinda tucked upward.. its a 2 wire/pin blue connnector...jump it and turn the key to the on position. your check engine light on the dash should flash a series of codes...long and short blinks. count them and post what you got...
Originally posted by iamdoby4life View Postwhere at in that section?
My car did that. It idled really rough, and surged. Then the CEL would kick on, And it would smooth out alot. I cant say What exactly I did to fix it cause I changed plugs, wires, cap, rotor, cleaned my IAC, Fuel filter, air filter, and ect, But that sure took care of most of my idle, and surging problems.
Originally posted by iamdoby4life View Postwhat pattern means what?
like what is the meaning of the patterns..?
quick quick quick is code 03 (no long blink and three short blinks= 03)
long quick quick is code 12 (one long blink, two short blinks)
long long long would be 30
for example.
Once you have the codes, write in and we'll tell you what they mean. Or maybe a list of them is in the stickies.
