Rear engine mount question
    I think my rear engine mount is going bad n this is why,
    when i accelarate for alittle bit then try i stop to reverse, in the action of reversing i hear a crack sound
    n then when i go to accelarate foward i get the same thing but when im driving on the road i dont hear it anymore
    could it be the rear mount?
    something is twisting to cause it to make a noise, mount, axel goin bad, loose rear mount bolts. i've found that the tranny bolts tend to come loose over time. ive have 2 back all the way out and i put them on pretty tight to start.
    the rebuild!
    http://www.cb7tuner.com/vbb/showthre...50#post2073450
      Both axles r new but ima chrck out the rear mount
        is it automatic? my white ex did it.... i couldn't find why it did it when i reverse... 3 years later while i was working under the car i saw the bad motor mount. so in other words yes there is a good possibility it might be the rear mount.
          standard, but yea ima check it out though
            turn your car on. with the hood open, rev the engine high..if you have a busted rear mount, you'll see the engine flex
              W/ really bad mounts you should be able to rock the engine by hand, grabbing both manifolds or even trying to roll the car while it's off and in gear w/o the ebrake. Visually inspect all 4 mounts though.
                should definetly check out the rear mount i have that problem an my solution is to get bolts that hold the bracket to the engine for the rear engine mount which also bolts to the tranny
