Oil leak in...
    Oil leak in...
    I got an oil leak in my spark plug cylinders..how bad and how much to fix?? and is it worth it??
    Not to bad to fix if your good with your hands. You have to pull off the valve cover and rocker arm asembly if im not mistaken. If you have an hanes manual just follow the directions on there step by step and you should have no problem. If you buy the felpro kit at autozone is should only cost you about 20.00 bucks or so. I would replace everthing while your at it.
      Yeah I did this a while back and got the valve cover gasket and the upper spark plug galleys seals for like 15 or so. I didn't know there were also 4 more seals underneath all of that. Those are the ones the guy above me is talking about. It won't be too expensive, moreso time consuming. It's an easy fix though.
