What kind of differences are there between ebay and brand name strutbars? ive found that sometimes ebay parts are fine, but other times im just wasting my money. So my real question is, Are the ebay strut bars worth my time at all? or should i just go ahead and find something nicer?
strut bars?
http://www.cb7tuner.com/vbb/announcement.php?f=17
Not too much really. If you get a solid steel one that would be better.
Those generics...most have an aluminum center bar, so if you COULD find one like those generics you'd want it to have reverse threads on one side so you can install it easy, and then tighten it down.
neuspeeds are excellent from what I hear
http://www.cb7tuner.com/vbb/showthread.php?t=36537____
The Neuspeed bar is amazing. It won't work with a DOHC swap, though.
I have a Megan Racing bar, which is a knockoff of the DC Sports design. It's very solid. The cheapie bars such as the "Tuned by Matrix" ones are absolute trash.
If you want cheap, get the Megan Racing bar. If you can afford it, Neuspeed is great. ESP (you can find them in their Member Shop here) makes a good multi-point bar too.
Ebay is NOT a brand, it is a store...
carry on....
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
Originally posted by bcjammerx View Post
If people are using this page (and other equally suspect ones?) as a resource to further their understaning of suspension systems, then it certainly goes a long way toward explaining many of the persistent mis-understandings that keep cropping up on this board.Regards from Oz,
John.
Originally posted by midnightsun View Postget a solid one piece design for best results.
What is important is that the brace is rigidly constructed, and typically this isn't usually a problem with the brace tube, but often is for the end brackets. The brace is only as rigid as it's weakest link, and if the end brackets aren't robustly constructed and well designed then the brace will not work well as it should (i.e. it will flex under load).
End brackets should be made from thick steel plate (5mm would be OK), and be designed in such a manner that the forces acting at the point where the tube attaches are reacted into the top of the tower without flexure, meaning the bracket needs good integral bracing in it's design and not be relying merely upon the metal thickness for strength.Regards from Oz,
John.
Originally posted by bcjammerx View PostNot too much really. If you get a solid steel one that would be better.
If you know what you're looking for, you can see this just by the visual appearance of the brace (with particular attention to the end brackets).Regards from Oz,
John.
Originally posted by CustomLowz View PostEbay is NOT a brand, it is a store...
Originally posted by johnl View PostThere's quite a lot of variability between the rigidity of the various tower braces. Some are very weak, others very strong...
If you know what you're looking for, you can see this just by the visual appearance of the brace (with particular attention to the end brackets).____
Originally posted by bcjammerx View PostTrue...but the ones off ebay (generics) are aluminum...not very thick either...and I would believe a steel one would be better...
Originally posted by bcjammerx View Postespecially if it had reverse threads on one end..then you could tighten it after install...my big gripe with generics.
Originally posted by bcjammerx View PostWhile different steels would give different rigidities,
Originally posted by bcjammerx View Postthey'd still be better than those generic aluminum ones...and there ARE good aluminum ones...I doubt off ebay though...that was my pointRegards from Oz,
John.
