same f22?
    same f22?
    will an f22 from a fith or 6th gen accord drop right into my 1992 accord?
    like i want to know if its a perfect fit and what i would need to do this
    also if its possible which of the newer f22 should i pick?
    Best f22 there is happens to be found in 90-93 accords
    wat?
      really? why is that?
        the f22z2 had more hp and torque why is that one not better?
          F22Z2? No such thing.
          The F22A head flows better than the F22B1 or F22B2, especially after some modification. The 6th gen Accord had an F23A1. The F22A head has more potential than the F23A1 head as well.
          The F22B1, F22B2, and F23A1 do go into our cars, but they aren't direct swaps. There are some things that need to be done, similar to an H22 or H23 swap. The F23A1 from the 6th generation Accord is the most difficult because it's an OBD2 motor only. There are no OBD1 ECUs made to run it. The P0A from the F22B1 is often used, but it's not the correct ECU.
            Originally posted by deevergote. View Post
            F22Z2? No such thing..
            Aussie or Euro market.
            1996 Honda Civic LX 2009-2012
            2012 Kia Optima LX 2012-2013
              If it's a Z block, it's just a replacement block in the Australian market.
