is it possible to change out the final drive for a taller gear?
    i have a 91 accord 2 dr exr coupe standard.
    on the highway @100km/h the needle is at 2500rpm. i much prefer it to be around 2000rpm. any cons to doing this? can this be done? anyone done this yet? thanks.
    I don't know of anything taller than the stock gearing. I'd love to do this to my H22 transmission, as my 5th gear is considerably shorter than an F22... and I don't use 5th for racing!
    Unless someone knows of something taller, I would think the only way to do it would be a custom gearset... and that would be quite pricey. More than the value of your car, I'm sure.
      you're probably right. the only other car i can think of with tall gearing is the civic vx, but that cars hard to find and likely swapped out with more powerful engine and closer ratio tranny.
        Yeah, and from what I've read (I'm no expert... barely a beginner) the D/B transmissions are made much differently than the F/H transmissions. The parts wouldn't be interchangeable.
        If you want something custom, I would contact Gear Speed. www.gear-speed.com
        They do amazing work, and they're very familiar with Hondas.
