gas pedal question
    gas pedal question
    i be driveing down the road and i be lettin off the gas and it still pulls but im not holdin the gas pedal in what could cause that
    sticky throttle cable?
      Or, the cable sheath has become dislodged at one of it's ends? (probably at the pedal up under the dash).
      Or, the throttle shaft (in the throttle body) is sticking...?
      Regards from Oz,
      John.
        Come on now... you're a big boy. You can use big boy words. I know you can do it!
        Are you automatic or manual? Auto will continue to pull at idle, manual should not.
        The suggestions above are most likely, though.
          wasn't this JUST asked? Cause I remember saying "Or a sticky throttle body"
          I remember spelling it out just in case noob didn't know what TB meant...
          ____
