block questions
    block questions
    what's the difference between a long block and a short block? and what's better?
    While searching Google your question, I found this in the matter of seconds...
    Long Block and Short Block are just terms that spell out what you are getting included with a Rebuilt or New Engine. There is no difference in the length or width etc, dimensions on both are the same.
    A Short Block comes with the engine block, crankshaft, rods, pistons, oil pan, oil pump, all the bearings, timing chain or belt, cover etc. A Long Block includes everything with the Short Block, but also includes the cylinder heads and valves, and cams. With a Long Block all you need to do basically is install your old Intake Manifold and Exhaust Manifolds, Ignition and Fuel Systems, and other accessories (alternator, air conditioning, power steering etc) and your ready to go. The main difference is the short block does not come with the Engine Heads and Valves, you would need to overhaul your old ones to put on the New or Rebuilt Short Block.
      thanks
