idel problem??????
    idel problem??????
    i just got done re building my motor and i got new plugs,and wires a new throttle body. and couple new sensors and cleaned everything up,and like it idel up and down like a weried way but after i get on it its fine but it wants to die when i put it in Netrual.but i need help on it cause i just had a baby and i gotta get it fixed asap
    Check to see if the vacuum lines are in the right place.
      ive check,but do you have a digram for a f22a6 cause i have a a1 bottom end and a a6 head on and i thought i had it on there right from the hood sticker thats on there
        try to set your idle up higher.
        there's a screw on the intake manifold to set the idling.
        Yes my name is Dang, Don't use in vain
        1992 Honda Accord EX (Coupe/Bordeaux/Auto)
        1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
        2008 Honda Accord EXL (Coupe/SanMarino/6spd)
          alright i just did that and it stayed for a sec then its started going up and down like it didnt have any power till after i took off then it was fine while i was in it the i stoped and it started
            bumpty bump
              to me sounds like iacv
                try to unplug iacv and back up fuse(top right) in fuse box, wait like 5 mins, plug iacv then back up fuse back in, see if that will help
                  Get a can of carb cleaner or brake cleaner and spray around the intake and throttle body gasket and around the vac hoses and if it corrects itself then u have a leak.Also undo the intake hose or tube and block with a rag or ur finger the hole on the throttle body and if that fix ur idle then the iac valve is bad.Those are some quick checks u can do.
                    were exactly is that screw for the idle pics welcome thanks
                      it has a a6 head can u put a picture of the lines up so i know if i have them right
                        bumpty bump
                          that throttle body is different than mine
                            nice drawing
                            http://www.cb7tuner.com/vbb/showthread.php?t=90574
                            check that out
                            make sure you've done the "if you've's" listed...if your not sure what they are search for them..if you can't find out let us know
                            ____
                              that little thing didnt help
