That's very generous of you, however I need a PT6 ECU. I'm thinking about running a hot wire straight from the distributor to the battery and stem ideas from the result
engine swap malfunction
I would strongly suggest using battery cable for that... higher gauge wire will most likely get too hot and may melt ( O_O ) or not provide enough current, giving you a false test result.
More than likely, running a hot wire directly between the two won't help very much. The problem is probably from a bad ground somewhere, so you can run a hot wire anywhere you want and it won't do anything unless you create a new ground for it.
Check grounds. I had to take my car to Honda when I did my first timing belt change because the engine wouldn't turn over... They charged me $400 to tell me that I forgot to reconnect the PGM-FI ground harness. One loose connection can make or break everything.
----I think I need to give up on timing belt changes. I have the worst luck...GO BIG ORANGE!!!
h22a swap/f22 tranny, 2.5" Magnaflow cat-back (well, the cat is gone now >_>), p/s delete... new stuff all around...
Originally posted by CB7Man View PostNo, a battery is a storage device
Not a dampener....
A dampener would be something like the Voltage regulator on the Alternator
If I were him I'd clean and reconnect the T-stat housing ground
It may be that the alternator will charge furiously because as far it 'knows' it's trying to charge a completely dead battery, and because no battery actually exists that energy has nowhere to go but into the electrical system because there is no 'reseviour' to store any surplus energy being generated, thus possibly causing overheating of components within the system...??
Whatever, I wouldn't risk it...Regards from Oz,
John.
The car will turn over everything electrical turns on just fine; my radio instruments fans all that stuff, just no spark, maybe I have the unbelievably bad luck of just happening to have two bad distributors? I'm gonna take it to orielly's tomorrow and just see for certain. One thing though, on my other car, when I go to start it the tach reads like 200 rpms while cranking, this one in question stays a zero? what does it mean? My camshaft is turning so it is NOT the timing belt
Originally posted by GenshiAri View Postmaybe I have the unbelievably bad luck of just happening to have two bad distributors? I'm gonna take it to orielly's tomorrow and just see for certain.
The ignitor is damaged by excessive impedence in the HT leads, which tends to cause the ignitor to overheat. If you ever have an ignitor fail and replaced, to avoid a possible brief life span from the new unit the lead resistance should be checked (been there).
It may be that this is the root cause of many ignitor failures(?), i.e they fail at X mileage because at / near X mileage the leads will often have become resistant enough to damage the ignitor.....
Originally posted by GenshiAri View PostOne thing though, on my other car, when I go to start it the tach reads like 200 rpms while cranking, this one in question stays a zero? what does it mean? My camshaft is turning so it is NOT the timing beltRegards from Oz,
John.
As deevergote said before... check the grounds, but be sure to check for missing wires as well. I almost missed putting the ground from the valve cover to the body back on. Its sometimes the little things that make all the difference I'd say check the main relay and fuses... but you've said that you did, not that it would hurt to double/triple check em.
as for spark, make sure that coil is attached. I've heard that its possible to actually jury-rig those things... but its not exactly a good idea. Someone told me that they new some people who pulled a practical joke of replacing the coil wire with vacuum hose (with covers & such from the wire) and then waiting to see if the guy noticed... he started right up and drove home! they checked it the next day, and the hose was still there goes to show ya what those things are capable of! anyways....
Just keep checkin those wires. one will turn up, and the thing will take off again... just don't give up!
