H22A dies while stop or just lags durring accel
    I have been reading around as to what i should do about this problem. I was driving around and it kept cutting in and out every so often. I would stop and it would just die. It would start right back up and everything, but I am at a complete loss at what to do here.
    This is what I think it might be (please correct me if I am wrong)
    1.Needs new wires (dizzy was completely changed)
    2.Needs new Cat
    3.Unblock EGR and clean EGR
    3.Main Relay
    4.Fuel Pump
    Thanks in advance
    The CB7 Collector.
    Team Kindred Impulse Member #3
    92 LX Coupe F22A1
    2013 Toyota Corolla S
    92 EX Sedan F22A1
    Do you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
    *Kinda Related*
    I had this '03 Civic Hybrid today, had the same problem you're having. Well it will only stall in Park. And everytime you tried starting it would die, unless you gave it gas.
    Hooked up the Honda HDS, and noticed that the EGR was getting stuck open at 1.48 when normal should be like 1.10.
    To make a long story short, replaced the EGR valve, problem solved.
    My suggestion is to make sure all the little things are right. Don't try to over think it.
      i would look @ the fuel issues 1st. had that problem in my eclipse and i found that it was my injectors, and my fuel filter.
