bisimoto pistons and rods
    Smart. A project car makes a lousy daily driver, especially if it's boosted!
    I have 3 cars. One is driveable right now. And even THAT needs work!
      going to order some bisi f22 rods. yea imma need a dd after all this bs
        Compression wizards..what would his compression be??
        H23a engine
        H23a crank
        F22a/h23a bisi rods
        H22a mahle slugs
        H23a head
        I'm aware the compression would go up.. but how much so
        Considering the mahles are 9:1..
        Praise The Lowered...
          H23a engine
          H23a crank
          F22a/h23a bisi rods
          H22a mahle slugs
          H23a head
            We'd need to know the compression height on the pistons and the dome cc.
            But assuming the CH is the same as the stock H22's, and by taking into account that a USDM h22 pistons(-2cc dome/31mm CH) in an otherwise stock H23 would put you at 11.0-11.6:1 depending on HG. So I'd say close to 10.5:1 or so.
              ha.. i figured it would be around that.. i thought closer to 10:1 but regardless.. looks like hes gonna have pretty decent torque band when all said and done..
              his original goal was 300wheel.. with that compression i dont see that as being a problem.. at even a mier 10psi
                according to this, http://www.importperformanceparts.ne...old-honda.html the pistons are -7cc. That would put the h23 at 10.7:1.
                Regardless, 10psi on the correct turbo should make well over 300whp even on 9:1 compression, given the rest of the engine can breathe properly. I think Mike(lodollar) told me he made over 300 on 8psi on 8.x compression(i think).
                  good shit then.. since the compression is being raised.. obviously its from the pin location being lower on the piston( thus allow for a taller deck height).. now my question is..
                  will they.. and if they do.. how much... will they come out the cylinder?
                    They'd stick out .02", just as it does on my H23 vtec. I'd recommend a thicker HG to lower compression and be sure the valves don't touch the pistons due to the different valve reliefs on the pistons.
                      does cometic sell for h23? i doubt it...??
                        doubt it
                          should i just reuse the factory rods and pistons and just get aftermarket rings. isnt 10 a lil to high for boost?
                            got my pistons now waiting on bisi rods and heat shield intake gasket. just waiting on response for head gasket from bisi.
                              got my rods in yesterday but it gonna take bisi a week for that headgasket. any more suggestions u guys got for me?
                                im running bisi 10.5-1 compression pistons and there H beam rods and im turning 9500rpm so needless to say im happy as can be. they are not cheap but they are worth every penny
