Buying 93 ex coupe 5spd need some feed back
    So i was looking around for an ex coupe for a while and i finally found one. The guy selling it says he put new engine with 106k, 2 new front tires, sway bars front and back,intake,headers, and full exhaust. The only problem is that it needs a new fuel pump for sure. So im going with the walbro 255lph. The price is 1000 but of course im going to try to lower the price couldnt hurt right?. Any ways is there anything else i should be looking into before i decided to make a full decision ?
    Thanks
    wow. i'd get it.
    drive it first of course and see if there's anything out of the ordinary.
    1000 dollars. pretty cheap.
    93 EX Coupe with 5-Speed?
    Yes my name is Dang, Don't use in vain
    1992 Honda Accord EX (Coupe/Bordeaux/Auto)
    1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
    2008 Honda Accord EXL (Coupe/SanMarino/6spd)
      That does sound like a good deal, but I would rigorously check it out, especially for modifications. If everything checks out, get it, but don't be too greedy with the price. It's already a good deal for the mileage, that is, if everything is running fine.
      "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
        Just go with a stock replacement fuel pump, getting that one will only waist money.
        "The Turtle"
        DD/Trail Rig/Mud Bug
          a few ppl told me about walbro was the right way to go though ?
            I think you should check the car out completely and then give him an offer. You stated that it needs a fuel pump. I wouldnt buy a car for $1,000 if I couldnt hear it run.
              Hell yeah Id def buy it, sounds like a great deal, i would also fo with the stock pump as well, use the money elsewhere, mods wise
              Its more than a hobby, it's a lifestyle!
                If you're not going turbo, there's no need for the Walbro pump.
                Also, make sure that the main relay isn't bad. It's what turns the fuel pump on. It's very possible that the main relay crapped out, not the fuel pump (the relay is MUCH a more common part to fail, and the hot weather is when it goes out)
                  Unfortunately, i wanted to long to get the car. He find some sucker that paid like 1500 on the spot lol but im just going to work on mine for the time being
                    If the fuel pump really was bad, then you're better off. Changing the fuel pump requires a LOT of things to be replaced at this point. Once you drop that fuel tank, just about everything holding it up has most certainly rusted to shit. A friend of mine said he'd rather cut a hole in the metal of the trunk than drop the tank...
                      dang that was a reallly good deal my 92 costed alot more than that.
