Maybe the problem some of us have with lower octane fuel, is that is becoming stale, the majority of cars on the road today require premium. Great example here in texas, when hurricane ike struck, and it was the aftermath, all the premium & plus was sold out of almost every gas station around, but there was an abundance of regular, and I could fill my car up anywhere, even though it does seem to like a higher octane fuel then 87. Everyone else was driving around to find 89/92.
Alcohol added to gas???
Octane Booster recipe
(1 gal) of xylene or toulene ... mix in 4 oz of marvel mystery oil for every
1 gal of xylene/toulene ... make sure the xylene/toulene mixture in your tank is no more than 20-25%
Ahem..
Also, theres word that adding some acetone (ie: 2oz to 10gals) gasoline will double fuel mileage
Originally posted by Honda Power View PostOk so I know not to put alcohol in it now and want be doing it again.
Same goes for E85.
But whats this about Pure Acetone?
Does it really help your car that much or is it like the alcohol "just a bunch of BS"?
I'm going to look into it but I was woundering if anyone has tried it?1992 Prelude S w/swapped H22A
you don't get more mileage out of higher octane rating...more then likely you ran higher octane during the summer and compared it to low octane during the winter...
During the hotter temps your car runs leaner as a result of less dense air and faster warm up times...I run 87 octane all the time...I get higher mileage (440 miles per tank summer vs 375 miles per tank winter). Upping the octane will do ZERO in our f22ax's
Prove it or stop saying it.____
Originally posted by Honda Power View PostIt keeps temps lower, burns cleaner leaving lease carbon build up, and it lowers compression.
Originally posted by Gotz Cb7 View Post93 burns better. I get an extra 30-40 to the tank with 91/92/93, than I do with 87. No performance gains whatsoever though. I just run 91/92/93 here and there to clean the system out a tad.
Originally posted by cloudasc View Post
Alcohol also destroys parts in the fuel system that are not meant to take it.
Don't put e85 in your CB7. Cars that are meant for e85 have special fuel components and have there computers programed to properly run e85.
Originally posted by bcjammerx View Postyou don't get more mileage out of higher octane rating...more then likely you ran higher octane during the summer and compared it to low octane during the winter...
member ride thread
DIVULGE MOTORSPORTS
Now what about us H series guys and boosted guys? And the seafoam thing works really well cleans out your car really well. I did it on my prelude and she ran alot better....The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
Your quoting EJX_Michael.Last edited by cloudasc; 07-04-2009, 02:04 AM.
Originally posted by HappyGilmoreX View PostNow what about us H series guys and boosted guys? And the seafoam thing works really well cleans out your car really well. I did it on my prelude and she ran alot better....
seafoam is a cleaner, and is fully combustible, unlike store bought alcohol.
But the gains are not from running the burnable seafoam...it is from the opening of the intake passageways via cleaning crude, better response as a result of the TB being cleaned up, maybe a better spray from the injectors being cleaned, reduction of carbon buildup on valves, and better flowing oil passageways.
I doubt your mileage or performance suddenly dropped when you refilled your gas tank.
...apples and oranges those two engines though.Last edited by bcjammerx; 07-04-2009, 02:22 AM.____
why u should use a higher octaine
Originally posted by 93F22A6 View PostThis makes me want toWhy are you running 93, 87 is just fine for our cars. Unless it's an H22 or anything with 10.5:1 compresssion or higher. If you add anything make it an octane booster, fuel stalbilizer, or fuel refiner stuff(made by stp). Also when you mean you changed your timing, what too?
Originally posted by pablo1990 View Postthe higher the octaine the better the output cheapest way to increase horse power but u must drain ur tank of 87 oct. gains about 4 to 5 hp and its better for ur car
The only time a higher octane fuel will increase power (other than there being a specific problem with the lower octane comparison fuel, e.g. stale etc) will be when the engine actually needs the higher octane, i.e with higher compression or with higher boost (the fuel can't tell the difference between high compression and high boost).
If you run a modern engine that is designed for higher octane fuel on a lower octane fuel then the engine will 'knock', and the 'knock sensor' (if fitted) will detect the 'knock' and the ECU will retard the ignition to reduce the severity of the 'knocking'.
Retarding the ignition timing will result in an instantaneous power loss and worse fuel economy, but when you refill with high octane fuel the 'knock' will cease, the 'knock sensor' will detect this and the ECU will advance the timing.
Result, magic power increase with 'better' high octane fuel, leading to the utter myth that higher octane fuel per se gives superior performance and economy than lower octane fuel...Regards from Oz,
John.
Originally posted by pablo1990 View Postthe higher the octaine the better the output cheapest way to increase horse power but u must drain ur tank of 87 oct. gains about 4 to 5 hp and its better for ur car____
They do this because of emissions. Even though E85 will hurt our cars, very light blends of regular gas and ethanol (around 10%) will run fine.1992 Prelude S w/swapped H22A
Heres another funny thing, and i've noticed myself. Its better to fill up your gas tank at the coldest time of the day/night possible, there appears to be a higher energy content in the gas when its colder, and less amounts of energy during the hottest time of the day.
I don't per say believe they increase the ethenol content in the winter, the ethenol content is static, the oil industries save money buy mixing in ethenol, so one would think they would mix as much ethenol as permitted all times of the year.
A couple factors for lower mileage during winter. Your car takes longer to warm up, oils take longer to reach optimal temperature, and the oils in your engine/transmission don't lubricate as well while cold. Also with the cold denser air entering the engine, the ecu will dump more fuel to compensate.
