Originally posted by 93F22A6
View Post
Regarding the Alcohol, it won't do anything for you. It's mostly psychological. High cylinder temps aren't necessarily bad, and can actually help combust the gas mixture. The best way to not get carbon build up is to not buy the cheapest gas you can find. It won't do anything to compression, someone probably said that to rationalize the loss of power. It does have water in it, it will eat at the rubber.
If you want to run a cleaner through your engine, buy Seafoam, STP, etc, chemicals designed for either octane boosting or engine cleaning.
