Originally posted by cloudasc
View Post
Alcohol added to gas???
My understanding is that fuel blends (ignoring anything to do with alcohol contents) do change to some degree according to the time of the year. In winter it's likely that the fuel will be blended with higher levels of 'light aromatic' components that are more volatile and thus evaporate more easily.
This tends to make cold starting easier. In summer cold starting isn't such a problem, so lesser %s of lighter components are needed. I would expect this to vary from area to area, depending on local temperature variability.Regards from Oz,
John.
Originally posted by johnl View PostMy understanding is that fuel blends (ignoring anything to do with alcohol contents) do change to some degree according to the time of the year. In winter it's likely that the fuel will be blended with higher levels of 'light aromatic' components that are more volatile and thus evaporate more easily.
This tends to make cold starting easier. In summer cold starting isn't such a problem, so lesser %s of lighter components are needed. I would expect this to vary from area to area, depending on local temperature variability.1992 Prelude S w/swapped H22A
