Alcohol added to gas???
    If you add plain rubbing alcohol to your gas does it help performance if so about how much?
    Also what problems might come up because of using to much?
    I already put 93 octane in my car because I changed the timing.
    Will adding alcohol to the gas help or cause more problems than its worth.
    How much is to much when putting alcohol in the gas?
    http://www.cb7tuner.com/vbb/showpost...53&postcount=4
    Ugh
    wat?
      no
      to achieve a Fuck, you must first give a Fuck
      Follow me on twitter @tru_whitetrash
        this is like spam mail
        -1992 CB7 EX w/H22 [sold 10/09]
        -2005 Legacy GT limited [current]
          This makes me want to Why are you running 93, 87 is just fine for our cars. Unless it's an H22 or anything with 10.5:1 compresssion or higher. If you add anything make it an octane booster, fuel stalbilizer, or fuel refiner stuff(made by stp). Also when you mean you changed your timing, what too?
          "The Turtle"
          DD/Trail Rig/Mud Bug
            Not for sure I set it back about a 1/4 inch or more Advancing it.
            I don't know the degrees but I have had it like this for a long time and it runs fine.
            My old CB7 I had I always put 93 Octane and it was fine.
            Also I added Alcohol to my old CB7 and it seemed to run better.
            I think I put all of a big bottle of rubbing alcohol in it too.
            I'm looking into putting some E85 fuel in my CB7 some time soon like the next time I need fuel.
              Can someone else explain this to this guy. I'm too lazy at the moment to type that much right now.
              "The Turtle"
                Yeah same here haha.
                wat?
                  add nitro.
                    Originally posted by wed3k View Post
                    add nitro.
                    lmao, yeah thats the shit.
                    "The Turtle"
                      What is the problem with it from what I have read it is suppose to be better for the car.
                      It keeps temps lower, burns cleaner leaving lease carbon build up, and it lowers compression. Although the lower compressions not what I want its good for the car. Lease carbon build up is always good. Lower temps could be a problem with sensors but it helps reduce heat ware.
                      I don't see the big deal with changing over to a different fuel or higher Octane fuel If it does all this good stuff.
                        ROFLCHOPPA...................................ok im done
                        (im not laughing at you mang.. just the responses.) ---ninja
                          You are aware that rubbing alcohol has water in it right? The shit you buy at the grocery store and drug stores are only 70% (same shit we use at our hospital in the Alcohol wipes)
                          Not a good move. IF you chose to try it, I would RESEARCH the HELL out of it just to be safe.
                          I on the other hand would not take that risk.
                          3 CB's gone....
                          1 WK Overland....
                          Still miss the CB though......maybe one day.
                            Ok for one higher octane in a low compression engine hurts performance. Octane is just the rating of how slow a fuel burns, the higher the number slower the burn, also resistance to detenation. Also, the alcohol eas rubber fuel line. Thats why.
                            "The Turtle"
                              dude you have to physically alter the internals of the engine to change the compression ratio. do you know wat is compression ratio?
