what all do i need to do to fix a broken head gasket?
how to replace a head gasket
remove the head, exhaust manifold, timing belt, antifreeze
youll be there all day btw
93 Accord LX Sedan (sold)
Originally posted by 09cb7 View Postare you serious, but its not that hard to do right? and what kind of head gasket would be good to buy?
Nothings hard if you know what your doing.
Get an Honda gasket kit, it comes with everything you need.
My 5.7 LS1 Holden Ute
He wants to buy a motor that has a "broken" head gasket, I believe.
When a head gasket goes, it goes because something bad happened to the motor. There may be more damage involved, such as a warped head.
The process involves pretty much taking the entire motor apart. The head gasket is between the head and the block. If you don't know what those basic parts are, then doing this job is very likely well out of your league.
Get a book... Haynes, Chiltons, or ideally, Helm. Follow it CLOSELY. Read and understand every word of the process before you touch the engine.
Originally posted by deevergote. View PostHe wants to buy a motor that has a "broken" head gasket, I believe.
Originally posted by 09cb7 View PostAre these book accurate on the motor, diagram, body etc.?
if you dont know your way around a motor or a toolbox you should probably pass this job to a friend or a garage that knows whats up.
not the kind of job you want to break your cherry on.....
yea this is where a 2nd car comes in handy if you were to do it yourself....shop will do it for about $600 range. GL dude!
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
The Haynes manual is alright... I'd steer clear of Chilton, as they cover multiple cars in one book, and it can get confusing.
But I agree with those above me... this is NOT a beginner job. It's possible to do it, but it's a lot to do when you're a beginner.
This is a fantastic guide that I'm using this minute to replace a head gasket on my second cb!
http://www.honda-tech.com/showthread.php?t=2335661
