enkei 15" lug nut problems
    I just got some enkei 15" rs5 wheels today on craigslist, the specs on these are 4x100/114.3. These should fit right? Problem is the lug nuts I got with them are coming loose driving down my street. No damage done because I stopped but I am wondering if I just need new lug nuts or what? I am hand tightening them when they are up and again when they are on the ground. Any ideas?
    look at the thread see if it bad.
    Go to home depot get Big Torque Wrench ($80)
    and torque it down to 80FT/LB i think
      Use a torque wrench.
      Originally posted by chessboxer
      We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
      Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
        thanks, I guess that was a dumb question, I just always thought you could hand tighten lug nuts and that was enough. I appreciate the help.
          the rebuild!
          http://www.cb7tuner.com/vbb/showthre...50#post2073450
            you can hand tight it then step on the handle of the wrench til it on tight...might be too tight
            That what i did before torque wrench
              Hand tight as in... spinning them with your fingers? Or hand tight as in using a lug wrench?
              I always use a lug wrench. Turn them until they stop, then put a little force on it... not too much. Not scientific, and a torque wrench is the proper way, but that's how I do it.
              Inspect your studs. The loose nuts may have done damage.
