axels or bearing
    axels or bearing
    ok so on my pass side i get like a huming/clicking nose and driver when i turn the wheel left it clikcs
    check to see if you cv boot is rip. It might be your axle.
    your CV Joint might be worn out
      whats a way to check if your bearing is done
        one way I've heard is to put the front end of the car up withtranny in neutral and spin the wheel while touching the lower control arm. It should spin totally smoothly, but if it's significantly gone you will feel a vibration through the lower control arm. If it's just starting to go you might not feel anything though because the bearing is unloaded in any direction while you are spinning it.
          http://www.youtube.com/watch?v=JSsC-...eature=related
          shake the wheel up and down to see if it shake
          Originally posted by evil_demon_01 View Post
          Wheel bearings:
          Usually first noticed by a humming noise from around one of the wheels when driving.
          To check the wheel bearings, you will need to jack the car up (so the wheels are off the ground)
          For the front wheels - Place one hand on the upper control arm and spin the wheel with the other hand.
          For the rear wheels - Place one hand on the upper control arm, or on the lower control arm and spin the wheel with the other hand.
          If the wheel bearing is bad - you will feel a "rough" vibration through your hand on the control arm.
          Also you can often hear a rumbling sound coming from the hub.
            ok deff my whell bearin on both sides..are these easy to change on your own
              not really, you need to press the bearing off the hub and getting the hub isnt the easiest thing to do compared to other models.
                Here is DIY
                http://www.cb7tuner.com/vbb/showthre...ighlight=rotor
                you will need to take Hub and Bearing to the machine shop for them to unpressed the old bearing out and pressed new bearing in
                Check your axle boot and look for any rip or leak. It might just be your axle not your bearing.
                if you getting bearing get Honda one.
                Majestic Honda have them for $50.
                if axle just get from local auto store. They should be ok (they only 50-$70) honda one will cost you $200+ (most of them time axle fail because of the boot fail)
                  If you don't want to rely on the machine shop to press out and install the bearings, try building one of these, this should do the trick:
                  http://www.backyardmetalcasting.com/woodenpress.html
                  all you need is a saw, some wood, some good wood glue and nails, and a bottle jack.
                  This one made of 2x4s seems a bit wimpy to me, however I've also seen one made with 4x4s by a guy who built his own airplane *completely* from scratch but I can't seem to find the link. He used through bolts instead of nails on his. One of these things is definitely on my project list, I've always wanted a hydraulic press of my own. Consider using eye protection when using just in case the wood breaks (also don't use a bottle jack that's much stronger than the wood frame and just in general use a little caution and common sense).
                    Originally posted by batever View Post
                    If you don't want to rely on the machine shop, try building one of these, this should do the trick:
                    Its actually not that hard but i had a lift and a shop full of tools
                    The local asshole, 19 years in the making and still not giving a shit
                    Originally posted by mj213
                    Wait... don't you have a carbon fiber hood? You need to give your "bro" a cunt punt.
                    Originally posted by bizzyboi
                    He will defend his stance on raping his car to no end.
                      is it easier to change the hole hub in stead cause i heard when you do that the bearing already comes pressed in ..and how do u tk it out
                        just take it to the machine shop and call it a day.
                          to much money
                            to much money
                            true that, i culdnt find a shop to do it for anything less than a hundred
                              doing a wheel bearing without a press or a machine shop is a real pain in the ass. I'm a DIY guy, but its worth the money to get them done then to whail at your suspension for hours.
                              Thats just me.
                              Also, double check your axle nuts are torqued down correctly. If you just did any work involving axles, and they are not torqued down, you can get this sound as well after some time. Tightening them up can make the sound go away.
                              BTW, if your brakes have any wear on them, now is the time to replace your rotors/pads. The pads are the easy part, but you need to press the hubs out to swap rotors. since they will be off anyway, its almost preventitive maitnence at this point.
                              -Big3racing.net-
                              My Build Thread. Many pics.
