91 pillar pod gauges.
    I saw a lot of accords with the gauges going up the pillar. Did anyone have to modify the pod because of the automatic seats?? 3 gauge or 2 gauge??
    Please let me know.
    You shouldn't have problems with auto belts. It goes on the a-pillar, not the top of the door frame.
      I know where it goes i have a 3 gauge pod. But i put it up to it and it goes over the auto seats. The Auto seatbelt harness comes down the pillar a little bit.
        Get a 2 gauge pod, cut your 3 gauge pod to fit, or don't use it at all.
        Those are your three options, choose wisely.
          i bought a dual pod from a DA teg, doesnt fit right but i got work to do
          UNDERGROUND SOCIETY
          NEW COUPE MEMBERS RIDE THREAD COMMING SOON
            Ya i think i am gonna shave it and then wrap it doesnt look bad.
              i Bought the cheap a** APC universal 2 gauge pod. just screwed it in yesterday an fits almost perfect. When you hold it up in place it doest look like it will fit but put 2 screws in the top and it'll bring the pod right against the A-pillar.
              Click For Full Details->http://www.cb7tuner.com/vbb/showthread.php?t=177213
              Chozen Few Customz _CT_
                Please let me know.
                Yes. There is some modifacation thats needed. it depends on what pillar gauge pod you get. For example:
                I used a 94-97 Accord pillar pod. The last pic shows where cutting is really nessesary on our 90-91 if you use a 3 gauge pod pillar. It dont fit perfectly but I did my best to get it to fit and look nice. With a little paitence and creativity you could make any thing fit.
                  Thanks for the help. that helps alot and i kinda figured that. Where did you order yours from??? Did you have to modify the bottom?
                    I ordered mine from Glow Shift. I wanted to see how gauges would look in my CB7. I got the Vacuum, Air Fuel Ratio, and Oil Pressure. The Vacuum and Air Fuel gauges suck. I see why the Air Fuel Gauge is useless. the needle fluctuates constantly! The Oil Pressure is a good useful gauge. I used the Greddy oil filter sandwich plate to mount the oil pressure sending unit. thats a good easy altenative as suppose to drilling into your engine block.
                    If I can remember I did have to trim the bottom a little to make it fit. I also read that the Acura Integra pods fit pretty good. I cant remember what years but if you do a search you should come across it.
