Shift problem
    Shift problem
    I have a 1990 5spd all stock. Sometimes at a stop light when trying to shift from neutral to first it seems like it does not want to go in? i have to go down to second then back to first, sometimes it takes a little while at a stop light to get it to go into first and it is really annoying. what can this be, if more details are needed please feel free to ask. I have owned for a year and never changed the tranny fluid, but everything else is well maintained.
    Can I get a Hell Yeah!!!
    Try changing the tranny fluid... when i first bought my cb shifting into gears was kinda hard, after i changed the tranny fluid it was a way noticeable difference.
      im running pennzoil synchromesh 2qts, great stuff.
        it's an old tranny...but refreshing the oil will help.
        Even after doing this mine still doesn't like to go into 1st...or reverse. But it doesn't do it as frequently or as badly.
        The way i get it to go in is that I have to let the clutch out a hair then it pops in. You can try that.
        The real culprit...I assume it's the syncros.
        ____
          ... or a bent shifter fork.
          Replace the fluid with synthetic Honda MTF, GM Syncrhomesh, or Pennzoil Synchromesh... if that doesn't fix it, I'd start shopping for another transmission.
            thank you friends
