lowering spring????
    lowering spring????
    i need some help on how far i can low my car if i going to lowered it?
    what's the normal hide ride?
    Not to be a smartass but pretty much as low as you want. The lower you go the more careful you have to be when driving. People have ripped off their oil pans and lips etc etc. Maybe i'm not understanding your question or it's not stated clearly enough. Coilovers are pretty much the best way to go but you're gonna have to pay to play. They normally give you about 3 inches or so to play with. That way if you do go too low you could always raise it back up some more.
      Some members on here are riding an inch or less off the ground.
        could you use coilovers from a 89 accrod or one of the newer models
          Why?
          You can use coilovers from a 94-97.
            Originally posted by deevergote. View Post
            Why?
            kk cool cuz i was tryin order coil overs and know one them for my gen so i was wonderin if theres was any othere models i could use thnx
              It's not safe to use suspension parts made for another car... if your suspension fails, you crash. You could hurt yourself, or worse, someone else.
              Just do it right.
                Just do it right.
                so dont use tha 94-97 springs
                  90-97 accords share the same shock spring combo, you CAN use the 94-97 springs and be safe, what deev meant was not to use the 87 accord springs or worse civic or integra springs. Some people have been asking those questions a lot lately.
                  1993 Accord EX
                  2011 Subaru STi
                    The shock valving may be different for the 94-97, but overall, they're similar enough to be relatively safe.
                    Regardless, there is NO good reason to ever use parts that aren't intended for your car. There are plenty of parts available that are correct for your application.
                      cuz im trying my best to not buy ebay coilovers jus that no company carrys 4 gen coil overs...but if i use the c.o from the 94-97 models they should go on no problem
                        Have you tired Mimo USA. They have an assortment. I'm actually seller for them. Just haven't put the website together yet.
                        Well there are:
                        Ksport Kontrol Pro Coilover Kits
                        The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
                        Key Features:
                        36-way adjustable dampening
                        Made from high quality 6061 Aluminum with T6 for increased hardness
                        Compression/Rebound adjustable
                        Adjustable spring perch for height adjustment
                        Adjustable body allowing maximum suspension travel
                        Pillow Ball Top Mount w/ adjustable camber (not available for some models)
                        Monotube High Pressure Design reduces oil leakage
                        Electroplated body for protection from corrosion and rust
                        One Year Limited Warranty
                        Don't know if your interested in those but they are available.
                        IridiumCore
                        HCK-The Beginning
                        Your drunk she doesn't look that good.
                          i have a skunk2 lowering spring..
                          it will lowered my front by 1.8 inch and rear 2.0 inch.
                          may be im going to put tom..
                          but tnx for the advice guys....
                            Nobody carries 4th gen coilovers? Where are you looking, Wal Mart? They're EVERYWHERE! The thing is to get quality ones... most of what you are going to find will be crap. Don't spend $50 on something that your life depends on (and for the love of god, replace the shocks when you lower your car!)
                              true i agree
                              2014 bisimoto parts coming soon
