so i know someone who is selling a kyb/ksport shock/spring setup off his eg hatch and i was wondering if it would work on my 91 accord sedan without and major modification.
suspension from and old d series on my cb7?
Originally posted by Shadow1 View Postwhat is with all these new people in wanting to buy suspension for other cars and putting on the cb?
the spring rate for the cb is different for the eg. the EG is a lighter car and will have your ride bouncy. your car weighs between 2900-3200lbs compared to the EG's 2200-2500lbs. DONT DO IT
x2^ You definitely don't want to compromise the suspension on your car, riding with incorrect/blown shocks/springs is never a good idea, not to mention dangerous. There's plenty of places you can get a good suspension setup for our cars for a decent price you just need to look around. If you're not going to do it right, don't do it at all.Still hustlin that Old Skool.......it never ends.
vv My Member's Ride Thread vv
http://www.cb7tuner.com/vbb/showthread.php?t=123371
What the hell does engine series and suspension have to do with one another?
A Civic may have swapped in an H22. Just because we can also use the H22 doesn't mean we can use the suspension components from the Civic.
i just swapped out my old crap and put in monroe quick struts from advanced autoparts i paid 266 for the rear and 280 for the front did the work myself like always and now my car is riding smooth. i also replaced the upper control arms, ball joints, tie rods ( inner and outer) all stock
i also put acura cl 2.3l front hubs and bearings on my 92 cb7 lx
stock calipers, brake pads
but i would NEVER PUT A CIVIC suspension on a cb!!!
ITS NOT CIVIC SUSPENSION! is kyb shocks/struts with ksport springs. its fit for a civic, but that doesnt make it civic suspension. it may still be softer than if it were purpose for a cb but it's still going to be a higher spring rate than stock. and he wants 350 for all, which is a hell of alot better than the 200/corner or what ever it would be new. believe me just because im new to this forum doesnt mean im new to cars.
Originally posted by rallyimp05 View PostITS NOT CIVIC SUSPENSION! is kyb shocks/struts with ksport springs. its fit for a civic, but that doesnt make it civic suspension.
Is it just me, or does that not make any sense at all?
Originally posted by Bullhorn7 View PostGUY you dont take bicycle tires and put them on your motorcycle so why take a aftermarket suspension designed for a civic and put them on a accord....Are you getting these analogies?
Find out the springs rates. Run them if they are on par with the same accord part.
Civic springs fit on accords just fine. THe only difference is the drop, since civic springs are a lot shorter. A 1" drop on a civic would probably be 2"+ on an accord.
The shocks...that's more of a concern than the springs. I wouldn't run civic shocks at all.
