I have the 10th ann edition & it has some issues. The D4 is constantly on even the car is n reverse. On the tranny side I get a loud clunk when I shift to reverse, & it is sluggish on takeoff. I was told to swap the TCU and some or all of this can be fixed. What are your thoughts?
TCU problem?
yo...i had the same problem with my cb...the d4 light constantly blinking,the sluggish takeoffs and it shifts only once....im assuming its auto...most likely either your tcu is bad or the transmission selonoids are bad....when my cb was having this problem i was lucky it was just the selonoids...a few bucks at the junkyard and i was good 2 go...about the loud clunk you hear, and i assume it jerks also....thats probably your transmission mount....i also had that problem....i replaced the 3 engine mounts and the tranny mount and it was good
My 93
Originally posted by ReGiCiDe93 View Postyo...i had the same problem with my cb...the d4 light constantly blinking,the sluggish takeoffs and it shifts only once....im assuming its auto...most likely either your tcu is bad or the transmission selonoids are bad....when my cb was having this problem i was lucky it was just the selonoids...a few bucks at the junkyard and i was good 2 go...about the loud clunk you hear, and i assume it jerks also....thats probably your transmission mount....i also had that problem....i replaced the 3 engine mounts and the tranny mount and it was good
Aight, thank you bro, Yes its Auto... I need to get a repair manual and learn some more about these cars, hopefully its just the soliniods.. thanks again
1993 - CB7 10th Anniversary edition
1988 - DA3 Special edition
