car wont start
    car wont start
    hey ppl some of u know some of u dont, im juice21's girl, he was trying to play mechanic on my car and now it wont start, lol. he showed me how to check for spark and fuel and we did and the car isnt getting any of em. we replaced the main relay and still nothing, and this all started because he tried to put his ecu in my car and then after that the car would crank very strong but will nolt turn over. so hopefully u guys will have some ideas. by the way its a 94 integra with an h22 swap.
    ps he forced me to write this to make me learn about my car
    http://www.cb7tuner.com/vbb/showthread.php?t=136667
    Bad ECU? If it started just fine with a normal one...then it rules that out as a possibility. Is it a chipped ECU? If he messed with the map he could have messed something up making the car not start anymore.
      well i forgot to add that he tried both ecus in his accord and it worked fine. he has a tuned p28 ecu and i have just a basemap p28 ecu, he was trying to see if his made much of a difference into my integra
        bump anyone had this issue before
          checked the ECU fuses, and the backup/radio fuse?
            ecu fuse is fine, but backup/radio fuse? think i noticed back up fuse looked a lil rough but ddint think that would affect the car starting
            edit this is juice21 ryt now
              when you turn the key to the on position does the cel stay on?
                theres no cel
                New & Improved 93 Accord EX Coupe
                what makes a man a man?
                Originally posted by ric3rboi23
                disrespect females, acquire currency.
                  it never comes on at all or it just comes on for 2 secs and goes off like its supposed to?
                    yeh the usual, but i cud be wrong ima double check n let u know, but if it stayed on i think would of noticed.
                      what happened?
                        Check your grounds. Might be something playing with you.
                          not sure about the teg, but I know our cars have an ecu fuse both under hood, and in the kick panel..... you check both?
                            Did you try putting the original ecu back in? If so, did it start with that . . . ?
                            My 5.7 LS1 Holden Ute
                              what happened?
                              found out it had nothing to do with the ecu
                              yeh had to take it to hr auto performance here in tampa, said the car had a couple shorts in the wiring harness and he did his best to repair it care starts up fine now, but after i got the car now i noticed brake lights not working, but he recommends me finding another harness.
                              yeh i checked bot fuses was wiring issue
                              the ecu wasnt the problem
