Two cooling fans would it be wrong too
    Wow
    Wow alot of good theories guys, I think im gonna just hook the other fan up to the connection it is suppose to have. I did find out that i do have a condensor, and i guess the fan turns on when the radiator infront of the cooling radiator gets hot enough. And no my car is running alright on the cooling perspective. The car has been sitting for so long so...1/took thermostat out, put it in boiling water and made sure it would open properly an buyed anew gasket, 2/oil filter with the TRT and new Mobil oil for a oil change,3/ flushed coolant and buying new radiator. I also baught new BOSCH Platinum 2 spark plugs Lol but come to find out i had BOSH platinum 4's already in the car silly me the guy that had this engine before me took really good care of it also. thnx for all the help ~!~PEACE~!~ Oja
    I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
    My Ride *****;http://viewmorepics.myspace.com/inde...lbumId=2844229*****
    Oja Thnx Everyone, at cb7tuner.com
      Originally posted by turbo90accord View Post
      gotta keep in mind too thought that it is also possible to overcool a system. Engines work best at operating temp and if you maintain a temp lower than that the ECU will make you stay in closed loop trying to get it to operating temp.
      I really dont think The ECU has any control over the thermostat, it kind of works independently,
        FYI: I'd stick to NGK quality plugs. Bosch do not consistently work well on our motors.
          you dont need it!! I thought about doing the same thing but it's not worth it if the engine runs in closed lope!!
          I just took mine out...Looks alot cleaner!!
          NO A/C, PS, or Cruze
          1990 Accord LX Sedan~Sold
          1993 Accord EX Sedan~Sold
          1995 Suzuki GSX-R 750~Totaled
            sorry to tread jack guys but i had a quick question. For some reason my car when it reaches its normal operating temperature the fans turn on but turn on freaquently. Im talking about 2-3 minitues after its turned on the first time, and now i notice that both fans are turning on. I already did a flushed and put new coolant, thermostat work fine. Is there something im missing?
              Its getting hot in Texas should be normal unless your temp gauge is going up I wold check elsewhere.
                No my temp gauge isnt going up but still worry about overheating the head. I think it may just be me tho but it gets really hot under there you cant touch the engine. I thought i read somewhere that if the engine is really hot that you cant touch the engine something is wronge or something like that. I just dont wanna mess my car up.
                  No the engine is normally hot...Your not supposed to be able to touch it...Especially on a hot summer day...WHoever gave you that info is unfortunately a retard.
                    Lol
                    nah i think ill keep my PS i dont want to be struggling turning and shifting at the same time.. now the condensor radiator and all that good stuff can be yoinked out of there cause ill just ride wid the windows down round herr Lol
                      I have the same problem on my girlfriends CB, both fans turn on at the same time.......... and it's been like that since it had the F22A.. which was overheated twice... now with the F22B i replaced the temperature sensors and still hasn't changed.... could be a relay problem????
                      Sorry about hacking on your thread, but i thought is kind of related to the topic...
                      JDM Parts for sale
                        But only one fan should turn on right?
                          One fan will turn on to cool the car...If it gets really hot both fans will turn on. Its normal on these cars unless your overheating which your gauge should provide info on that.
                            Actually....if all sensors are working properly the fans shouldn't turn on while the car is off.
                            If your car does it, just make sure the fans turn on while the car is on(when it needs to). My fans hardly turn on, unless I'm stuck in traffic for a while. My temps never go over 185*F otherwise. I *think* the temp for the fans to come on is 195* or 200*. They shouldn't turn on any other time. If they do, you probably have bad sensors or some wiring issues. But I woulnd't worry about it unless they seriously don't turn on at all while the car is on and you're in heavy city traffic.
                              At one time the gauge was going up while the car was idling. But the next day i checked the coolant and was some what low. After that the gauge needle never moved. I think everthing is ok then. Thanks for your help guys.
