speed sensor
    speed sensor
    ok guys i talk to my friend about replace the vss on my car and he went to buy it but later he ask me if is the one with the power steering hoses or not what does he mean please help me on this
    there are two hoses going to just under the VSS they are not connected to the plug part you take off idk if you can use non abs ones with it i think you should be able to.
      I had my clutch replaced yesterday. Today I am getting the Speed sensor CEL and my speedo doesnt work. The guy that did the clutch is insisting he didnt have anything to do with it, what do you think?
        Yes. The speed sensor should be unplugged and removed when doing a clutch. It was probably a) not hooked up or b) damaged. I would inspect it. It takes around 30 seconds to unplug and pull it.
          AFAIK 90-93 Accords/92-95 Preludes (maybe others) with speed-sensitive power steering run fluid through the vss for reference. I connected these to my H22 VSS just as they were connected to the F VSS from the factory.
          All the Civic/Integra VSS' that I've replaced omit this variability( 94-97 Accords also dropped that style of steering) .
            The hoses aren't for abs.
              where can i find it. Is it inside or underneath the car? I checked my haynes manual and i cannot find anything on the speed sensor.
                idk why i put abs in there that was my mistake.
                  its located a little bit farther under the thermostat housing it is on the tranny.
                    ...and right up next to the rear motor mount. 3-pin plug connects to the top, one 10mm bolt. And since it's an Accord, it will have two small hoses running into it.
                      ok so i am about to go do this on my car, does anyone have any tips? am i going to loose power steering fluid when i disconnect the hoses?
                      Behind Every Successful Person...Lies a Pack Of Haters!
                        i just swapped the sensor from one i got outta my parts car and it works fine, its a bit of a challange to get it out but its nice to be able to see how fast im going lol
                          Just sayin its a 10mm to pull the sensor itself. Not hard and disconnect the plug you do not have to pull the whole assembly out...Just remember when you realign you get that keyway aligned or the sensor wont read.
